Water leak in near side rear passenger footwell
I have a Polo Twist, 04 reg. water is gathering in the passenger footwell, rear, near side, I think it is rain water. I can't see any obvious places for the leak to come in, sunroof seams fine, so do all door seals.
I recently had the light cluster out and it wasn't replaced flush, there was a big pool of water inside above the wheel arch, I thought this was the cause of the water getting in and had it fixed, however now it rained again, the footwell is soaking but the bodywork near the light cluster s bone dry, so that must have been a coincidence.
Could it be the a/c vent? Am running out of ideas, thanks.
  • Views 2.7k
Best bet would be to sit inside the car whilst someone squirts it with a hose, then look for where the waters coming in! Or sit inside in heavy rain or something.
Personally i'd check the plenum chamber area under the windscreen, i'm not sure of the design on the modern Polos. But check that the cover is sitting correctly over your pollen filter, if its crooked (or sometimes they have rubber bits that can be bent back accidentally) straighten it up. Water could be running off this, through the filter and heater in to the car, then running to the back. Has the pollen filter or that area been disturbed recently?
Otherwise check the drains in that same area. The problem doesn't coincide with say the rear washer being used does it?
