Mk2f polo sunroof drain exits?
Got a leak in my car and des covered that the drains for the sunroof are completely blocked. Anyone got any use where they exit the car?
  • Replies 13
  • Views 1.7k
I think they are up in the wheel arch
The front wheel arch ?
Behind the rear bumper for the back ones and through the wing somewhere for the front ones.
I've unblocked the back ones with a compressed air line.
Also once you unblock them, check that they are draining correctly and not leaking into your car.
After a few years where the rear drain tubes connect can rust through.
So when you open the sun roof you can see the drain holes ?
In the boot next to the tail lights against the side of the car, you can put your hand down in there, the tube is in there on both sides. Exits in a hole right in that bottom corner of the panelwork behind the wheel.
I used a thick bit of wire, 6mm earth wire would do it, to clean it out. Not sure how good the access is from outside on big bumper models.
Fantastic shall check them and do as you say :smile:
Anyone had any luck at unblocking the front ones. I poked a bit of wire down it but it just stops. Won't go any further.
I used a length of washing line to unblock the front ones. It definitely worked as you could see the line poking out into the inner wing
Yes on a mark 3, you can see the end of the tube by the rear bumper. It should run through the rear pillars, past the tail lights and out by the bottom of the rear bumper. I tried unblocking mine with the washing line (like the front), but I found a compressed air line was much easier. You can test before and after with a watering can and pouring small amounts of water into the sunroof tray.
Did much crap come out ?
Anyone know how to get the headliner out?
slowly but if you rip it I have one and sun roof up for grabs 2013-09-05160556_zps8d8f92a0.jpg2013-09-05161804_zpsb6456cbf.jpg
