what to look for when buying a mk3
hi guys i am going to look at a 1992 mk3 polo coupé cl 1.0 4 speed what should i look out for on them ie. common this to go and rust where are the problem areas on these any help or information on them would be great
Paul
  • Views 885
Battery tray
Spare wheel well
Fuel filler neck (located inside O/S/R arch)
Those are the most common places on the early Polo's.
Spare wheel wells aren't a common place for rust on polos really
I would check the rear floorpans, as they have metal plugs which seem to rot, had to replace both sides on my GT and breadvan.
The sills can rust quite badly, particularly in front of the fuel filler neck, I managed to pull mine off, and the filler neck itself might be rusty.
As said the battery tray is probably the most common place, I've seen it on every early polo
battery tray rust /wet carpets....alot will have suffered here , not too bad to fix
petty tank filler is another common one ...again not the end of the world and most will need doing at some time
then just have a good look around , arches , sill , around the screen , good look underneath with a torch
most also leak oil from the headgasket above the alternator , so check for that and haggle some money off
Thanks guys I went to view the car and to be honest it was fairly clean arches are just starting to bubble and a wee bit at the bottome of the windscreen sills are solid tho over all I was quite iimpressed for a 21 year old car so got him down to 450 for it
Its a 1.0 coupe 88k with 2 owners previous paints a bit flat but should polish up fine aandi should be picking her up tomorrow if all goes to plan so when I do will post some pictures up of what I got
