Mk2f Loose Handbrake Button, suggestions?
Bit of a silly one but annoying none the less, the button on the end of my handbrake has come loose, it still works fine and reliably, it just seems the 'plastic' bit has come loose from what it should be attached too. This means it can be loosely pulled out one cm or so more and turned around, its all wriggly. Like this:
It can't however be pulled completely out so i can't see how it should be attached/get some glue in there, it gets to a point where it goes no further.
Anyone got a suggestion of how to fix this? Short of changing the whole lever.
  • Views 1.8k
Anyone? I keep playing with it when sat in traffic, sods law its gonna fall out at some point...
I can feel a hole on the underside towards the bottom of the 'grip' section, in the last finger recess i think. So i guess theres a screw? Going to have a look in the light when i'm free.
No screwdriver grips anything in the hole, it seems to be just a blank recessed hole. Any ideas?
not a great help but id just grab another one from the classifieds and swap it over
Yeah that's what I've been thinking, I've changed so much of my car now I'm'm just trying to keep a few original bits! Plus it would save money. I figured out the reason its done this too, when in traffic i rest the end of my hand on the end of the handbrake with my fingers on the gear knob in neutral. Whoops! I'm sure unless i improve it this will probably happen again.
I will pop the lever out when I'm home next week and have a ganders, if not then I'll find another.
