67k Polo GTI Engine
I have for sale a Polo GTI engine conversion. Ideal for MK1 or Polo Conversion
This is a 1.6 16v with 125bhp. It has covered only 67,000 miles!
I have spent the last 8 months collecting up parts to convert a 1.0L Lupo. I have accumulated about 90% of the parts needed for this conversion however circumstances have now changed my priorities and will no longer have the time to complete this conversion any time soon. So i have now decided to sell it on.
I would ideally like to sell this as a complete conversion as i know how hard it is to collect all the parts together.
So included in this sale is the following:
Engine (only 67k)
Auxiliaries (alternator, power steering pump)
Gearbox
Engine loom (complete and uncut)
ECU (from same car as engine)
Driveshafts
Radiator (with pipe work)
Subframe (including bottom arms)
Power steering rack (with most of the pipes. Will try and get missing pipe before sale)
Engine plastics
Interior loom (complete, including fusebox and relays)
Steering column
Pedal box (with drive by wire switch)
GTI clocks (correct mileage to engine)
Front 256mm GTI brakes (complete, hubs, calipers, carriers, discs, pads, ball joints and uncut ABS sensor)
ABS pump (including complete ABS loom)
It will need a clutch and there is no key. I do have the immobilizer box so you can just recode your key using Vagcom.
I have spent a long time collecting these parts and have spent over £900. I would like to recover some of my money.
Price: £500 collection only
JP
1D9A47DE-66ED-4C3A-AB02-9D988FC489D3-450
The Lump
C1F418F7-CE3C-48FC-999D-6943B8037821-450
Gearbox
A3F44F7F-6061-4F25-9F00-F4333949908C-450
Front Brake Setup
A3EF3D50-626C-469E-B72E-927277D528B8-450
Radiator
6A842CBF-87EB-4C66-BEE2-E69AF5DF1461-450
Pedal Box
3CED073A-B194-4A2E-AFC0-CD01E155C300-450
Steering Column
33097637-161A-4833-AA5C-D33F676FF138-450
Clocks
A6C18431-9B1C-43FC-99E2-F3BCCFDDB013-450
Interior Loom
th_0FFAAEEF-F8DC-4C7C-9D3C-69F6988C2D76-
Engine Loom
D7113D74-A2BE-46D7-BBF2-3137C2D8F63D-450
Header tank, ECU and ABS pump
B46E94C8-C159-4961-A77A-C8C2E49BC9A8-450
Subframe with ARB and Powersteering Rack
B2269313-3734-4FA8-A876-8964686A8A12-450
Drive shafts
A03F1DA4-83D8-4775-A3B8-B03155E374AE-450
Starter Motor
Edited by valley
  • Views 340
Have you still got this.... really interested in it
Edited by blackheathmh
Still here,
Forgot to put a picture up of the labelled up engine loom.
Sold
Have you still got the gearbox?
