Fuel gauge stuck (I think!)
So I filled my tank up the other day (car is a W-reg 1.4 16v), and since then the needle hasn't dropped, and at times is above 1/1 (i.e. full).
It drops back to 0 when the car is turned off, but as soon as it's back on it'll sit around at the top.
I've done about 50 miles since filling up, so am expecting some noticeable drop, but don't seem to be getting any.
I know nothing about how the fuel level is actually measured so any advice would be great.
Any ideas?
  • Views 1.8k
Hi,
The fuel is measured by the fuel sender/delivery unit under the rear seat located through a little access hatch directly into the fuel tank, I had a similar problem in my 01 plate GTi fuel gauge wouldn't drop bellow half way point, replaced the unit and all was fine, if you look on ebay you could get one for about £30-£40, it's a relatively common problem and it's a pretty easy job too with basic knowledge.
Just makes sure you de-pressurise the fuel system
Hope this can help,
Lewis
Turns out I was wrong about the needle being stuck, having done another 60 miles it has now started to drop below the full reading, so is actually making sense now.
(New driver, new car, apologies!)
Thanks for the reply Lewis, if nothing else it has educated me about the sender unit, I'll look out for any issues in the future.
Thread can be closed.
