2 speed radiator fan
Been looking at Polo and Golf wiring diagrams.
Is upgrading to a 2 speed radiator fan from a single speed fan as simple as replacing the radiator thermal switch with a 3pin one with 95 and 105 degree normally open contacts and fitting the fan from a post 1987 Golf or post 1990 Polo?
  • Views 893
There's only two contacts in the single speed plugs, so you'll need to add a wire and terminals at each end.
When I did it, I just chopped the plugs and soldered on spade connectors, but if you're getting precise, I'd imagine http://www.vehicle-wiring-products.eu have got the bits to add another connection or replace the plugs.
can rob all the parts from most golf mk2 (not 16v )
the little bit off loom comes off
Cool thanks.
So I bought a 2nd hand 3 pin 2-speed fan switch off eBay.
It's a 191959481A from August 1991 so Golf Mk2 era.
But does it need an o-ring where it screws into radiator?
Found it I think - maybe a N0438083 29x22 sealing ring.
yeah they have a brass ring...you can use the one off the old switch
avs car parts has new switches for about £8 or so...put one on the g60 a few weeks back
