How to make it easier next time
Thought id try and get a thread going, on how a job went on your polo and how it could be easier for you or someone else next time.
Such as;
Polo 6n2 1.4 TDI
This weekend i replaced my rear abs sensor, after trying to get it out by pulling with some pliers and a hammer and chisel to loosen it, it didnt budge. So i was left with a stump, so the drill was brought out which after drilling numerous holes, getting copper wire bits everywhere, i was able to break it in half with a screwdriver. But it still didnt come out, so i pushed it in the cavity behind the brake disc, so i had to remove the caliper to get it out. I also spend about an hour cleaning/re-greasing the pads and cleaning all of the copper and bits of magnet that had broken and stuck to everything, I'm expecting to have grooves in my disc so ill have to clean the friction material again to get rid of the magnets.
I later noticed the bolt holes for the tyres lined up pretty well with the sensor, so i could have just banged it out with a punch.
Last week i also tried my rear wiper washer jet, which worked.... sortof. So i tried it and tried it thinking it was a blockage, it wasnt, it went all in the car and stunk! Had to take the fluff from under the passenger side front and back out to dry it out. Anyway having taken most of the boot interior out i finally traced it to the rear door sill, behind the trim. There was a little push on connector that had come apart. You can get at it by pulling the door seal back a little and the plastic trim, near the top of the seat. If its not there then it will be in the boot lid which iv fixed already.
So iv basically wasted about 5 hours of my life in the last week.
Anyone got similar stories?
  • Views 796
People often do things the long way.
1974-1995 models
To change the front dampers and/or top mounts you do not need to undo any suspension arms. In most cases you don't even need to take the wheels off - just undo the top nuts, raise until you can squeeze clamps onto the spring to stop them expanding further, raise the rest of the way and you can get a hand to the top mount and withdraw it. Over the tyre and through the spring is enough gap to get the damper retainer off with pipe grips or the correct spanner. Withdraw the damper through the top mount hole. Reverse procedure. Last time I did it, took about twenty minutes.
Same on the back. Its two bolts either side. Wheel removal isn't necessary, andunlike the front, on the back this is the case for springs too.
You do not need to undo any part of the suspension to remove the engine, and you do not need a crane. Just disconnect the engine/gearbox from the car and lower it out by a trolley jack. This is a bit more fiddly in reverse due to getting the driveshafts on, easier if you disconnect the inner suspension arms and ARB mounts (but then that is just six bolts).
1999-onwards twin-cambelt 16v engines
You do not have to remove a cam pulley to remove the small belt. You do not have to undo the main belt tensioner to slip the cambelt off for cam carrier/cover removal, as the tensioner has a sprung release arm on it you can operate with a long screwdriver.
VVT versions
Do not remove the inlet pulley or inlet cam before marking the cam position with the pulley pegged in home position. Remove the end cap behind the coil and scratch a mark on the end of the cam in there and to the adjacent machined surface of the head. Keep the scratch mark far enough in so as not to affect the oil seal in the end cap.
This will prevent you loosing the pulley position, because it is not keyed to the cam.
Couple of universal tips.
If you've got a job to do on the car, give all the bolts a soak with penetrating oil the day before - except steering track arms, as oil getting into the tapered mating surface within the joint can make life difficult. With these, just brush the threads as clean as possible to aid removal of the nut.
Always grease threads before assembly. Some copper grease on exposed threads after assembly is good too. This will make it easier next time..
Its quite important, if you know there's something wrong with the car, fix it as soon as possible. Because it will get much worse very quickly. A small problem can turn into a big problem, nothing is more important than maintenance and preventative maintenance is the most cost effective and time saving.
Useful tips :) Keep them coming
Mikey, you have made my day! I need to change my front top mounts after the new ones i was supplied with were wrong so the rebuilt legs had to go back with old ones, i will definitely try that!
This is more of a cure but it could make it easier for some people. If you get in your 6n, possibly 6n2, and the foot wells have a inch of water in them look in your rain tray (blow the front screen) if that's full of leaves and random rubbish empty it out and it should stop your foot wells filling up with water. Worked for me just need to the car to dry out now :L
Also if you're having trouble getting the screw out of the door card that holds the tweeter to the door cards, in a 6n2, then just take the door card and tweeter housing off as one piece. Don't think it's physically possible to remove that screw in all honesty.
Edited by vdoubleu
