sold delete
delete
Edited by performancevw
  • Views 754
I've got one like that...ended up getting bead blasted and it looked as good as new
polishing will be a hard slog , if you really want to do it start at around 120/180 and keep stepping down the grades until its about 1500 then use metal polish
Try some Autosol? made all bare metal bits in my engine bay come up nice
if youre going to polish it id do it properly if i were you, just go through the grades of wet and dry untill you get up to 2000 grit maybe then get a polishing mop and stick it in a drill. a bit of autosol will bring it up nicely. then if you want the shine to last try using some sort of sealant like gtechniq or something to protect it from dirt and other crap. if i were you id just spray it though :) crackle black always looks quite good imo but suppose it depends what colour car it is and stuff
EDIT: Austosol can be bought from halfords, ebay, amazon etc.
Edited by VDUBDAVE
These look nice in crackle black with the raised edges of the VW roundel and the oblong sections polished alloy. Much easier to keep in check than polished alloy all over too,
Hammerite will probably be the best, you can get hammerite in spray cans.
