Mk2f coupe wet drivers seatbelt?
G'day Gents,
Over the last few weeks I've noticed that my drivers side seatbelt is wet when I use it??
The floor underneath it is dry.
The only conclusion I can put it to is the rear drivers side window leaking :/
Anyone else have any info on this?
Thank for your time Gents
  • Replies 9
  • Views 742
I hope its the window, would pop it out to check.
could also be the slosh overflow pipe for the fuel tank has rusted through. it goes from the rear wheel arch to just above the fuel tank under the rear seats. if its gone would get some mastic round it quick as water will be getting into the sill
you got a sunroof?
rotten sill /inner arch letting water on it?
It does have a sunroof.
Could the sunroof seal have gone? Or a blocked drain?? (I know nothing about sunroofs)
I'm going to give it a good clean and check the arch and fuel neck area.
I'll probably end up using window sealer on the window cause water does run out of the seal, on the outside.
I'd guess the fuel pipe option rusted, you can get to it by taking of the drivers side rear door card, you'll also be able to get to the seatbelt from there too.
I'll give that a go tomorrow then :)
Will report back with findings
Thanks for the help so far guys :)
This has been happening to mine and the mrs mk3's for a while, may have a browse !
Seems to have stopped since I white greased the corners of the d/s rear window.
Just picked up the flap and squirted some in, seat belt is now drying out :)
Thank you the help and hopefully it won't happen again xD
Strange, there normaly a snug fit those rubbers! Glad it's sorted tho, leave the door card in the back off to help the drying aswell
