What have I done? Gearbox problem!
I have a 1.6 polo gti, and the gear box has never really been great, and always a bit stiff to get into reverse, but today it wasn't really budging at all, so I pushed it pretty hard and it went in, all was fine until I tried going into 1st again and it would select any gears just kinda flops about, it still goes into reverse though? What have I done? And what can I do about it?
  • Views 678
  • I recon its almost certainly a linkage issue, only question is whether its internal or external. The external linkage is adjustable, so id start there. It would have been better to start there before
I recon its almost certainly a linkage issue, only question is whether its internal or external. The external linkage is adjustable, so id start there. It would have been better to start there before of course, giving it a load of testosterone isn't usually the way forward.. But if it wasn't tight and had slipped, then you may just have slipped it further and not actually done anything but move it further out of position.
Thanks massive help, would I be able to do anything myself? If so I would I go about it? Cheers
Have a look for any guides on setting it up, you can get somewhere near by manually putting the gearbox rod into the reverse gear, them putting the gear lever into reverse position, then nipping the linkage up. But that will only put it near, it will probably need tweeking after that and that can be tedious process. Having one person underneath doing the adjustment whilst the other sits inside going through the gears to see if its good, that's one way.
