Using body filler
Got that P40 and P38 can anyone send me any threads to using it the best way? Watched videos pretty much sure what I am doing just a little extra help
  • Replies 9
  • Views 1k
What are you using it for? p40 is fibreglass is it not?
It takes a little bit of practice to get the hang of it, but try not to use too much at once, as you'll end up just sanding it off, wasting time, sandpaper and filler
Want to start with some surface rust on the the door panels and other bits around the car, yeah that's correct got that for when I want to smooth the bumpers and that, for the rear badge could I use the fiber glass and then a layer of filler on top? Or do you have to weld a bit of metal over then grind down?
post-145536-0-46001300-1383169793_thumb.
I would weld it grind down and filler as been the boot it stands a chance it will crack with shutting it ect..
Edited by mazraclou
The fibreglass will be fine for the boot badge
Welding a bit of metal in would be the best thing but fibreglass sticks like shit to a blanket...
So just sticking fibre glass in there will be fine?
It'll be fine but after time it tends to leave a crack of an outline of what you've filled.
Can you not weld ? if not am sure you know someone that can ? it's the best way .
Alright cheers
Yeah I guess I could get a mate to, just thought it would be easier just to fibre glass it
