mk2 /2f roof gutter strips?
anyone taken the roof gutter trim strips off thier mk2
looks like i need to paint my roof so need the strips off idealy ...but they come off nicley enough to be reused?
  • Views 2.1k
They're held in place with Butyl...so heat them up before you try to take them off.
If you take your time and put enough heat on them they can be reused...be careful
as they are no longer made by VW and discontinued at the dealers.
Can there be anything else bought from somewhere else to be used instead of original items
I found if they're very cold they come off quite easy too as it becomes all brittle
yeah they are all old now so be very careful. but a bit of heat should help :)
I just slowly took my time with the ones I found at a scrappy. As Derkskine said, the cold did help. Just really! Take your time though :)
