Vw polo 6n2 1.4 TDi shaking problem!
Hi,
I'm having some shaking problems with my vw polo,
when i release the clutch all my dashboard shake and make so much noise and when the car is cold
this is worse.
I have replaced the transmission mount before a week.
What else might cause this ?
  • Replies 22
  • Views 16.6k
  • Hi mate sorry it's a bit late but I have the same car and the same problem. And I'm pretty sure it's just because it's a 3 cylinder. As for the dash rattling I've just shoved some folded up paper in t
Rev it a bit more?
Or does revs not matter?
Could be a problem with the clutch and flywheel or engine mount. Does it do it every time you change gear?
Rev it a bit more?
Yes it makes less shaking/vibration when i rev it, but still shaking.
I have replaced the clutch before a moth with new Valeo (Kit).
and the engine mounts looks in good condition .
Does it rev it when the clutch is in/out and idling?
Does it do it when wheels are up in the air?
Does it do it when driving with clutch up?
Sorry but i'm not very good with english so please could you explain me better ?
What do you mean with "when the clutch is in/out and idling " ? when the gear is in/out ?
Does it do it when wheels are up in the air? I haven't tried this.
Clutch release bearing.
That's why when you apply the clutch the rattling calms down.
is this possible ?
I Have just replaced the clutch with a new one.
You've fucked something up then.
I didn't replaced the clutch myself.
it was replaced by a mechanic with experience, and i had this shaking/vibration even before i replaced the clutch.
did they check the flywheel. how does the car feel whe npulling away with just clutch and no revs, any judder/shaking? have you checked ALL the engine mounts? and how is the cars performance, does it seem alright on power?
They told me the flywheel was in excellent conditions and they just cleaned it, when i pull the car without revs it judder/shake alot more.
Engine mounts looks good i have replaced the transmission mount before a week, and is alright on power no loss.
is there any oil leaking from the drivers side mount? i cant think what else. the obvious seems mounts and clutch/flywheel. is there a balancer shaft or sommit in these engines?
Does it do it when you just rev the engine in neutral?
Does it run really rough?
Is it otherwise fine when you are driving?
No there is no oil leaking.There is Vibration damper, and a balancer shaft (if you talking about this) CLICK IMAGE
Does it do it when you just rev the engine in neutral? there is a little vibration when i rev the engine in neutral (not so noticeable), this only happen when the engine is cold.
Does it run really rough? YES
Is it otherwise fine when you are driving?everything else seems fine, when the car is warm it makes less vibration/judder and this happens only in the first gear when i release the clutch without revs its very annoying.
Injector fault maybe?
Driveshaft isnt bent is it?
So its only when using 1st gear.
Does the speed matter?
Should i try first to clean my injectors ?
Driveshaft isnt bent is it? No.
So its only when using 1st gear ? Yes mostly when i pull the car, and if the car is with 2500-3000 rpm in first gear there is no judder/shaking noticeable.
You need to get it plugged into diagnostics. That should tell you more. Taking it out could just disturb it.
Id say its pointing to the injector
Or it could be a timing issue?
I was going to try a Liqui Moly (Fuel injector Cleaner) if you know.
And it could be a timing issue this cause most judders/vibrations.
Edit: And i think my car is taking long time to warm up
Edited by Julijan
you need vag com. you can be sure to if its warming up as should be and lots more other things. including the timing
  • 4 months later...
Hi mate sorry it's a bit late but I have the same car and the same problem. And I'm pretty sure it's just because it's a 3 cylinder. As for the dash rattling I've just shoved some folded up paper in the gaps and that's made it better. Hope this helps
Check the balancer shaft chain hasnt snapped
Did u ever resolve this problem?
  • 2 years later...
Check Injectors Electric connections ( take off rocker cover, plugs are as a pins ) if thats all fine get injectors tested, if all fine get the crankshaft timing checked.
Sent from my HTC One max using Tapatalk
