Limp mode on Polo with AMF engine
Hi there, I am from South Africa. I am sure this is an old question, just cant find the thread for it.
My 1.4 TDi Polo with AMF engine goes into limp mode. Replaced so far:- Airflow meter, Vacuum Block, charge pressure sensor on Intercooler. Cleaned EGR valve, Checked and repaired vacuum hoses. I am clueless. Help Please.
Franscois
  • Views 1.9k
Easiest way to find out what is wrong with it would probably be to hook it up to a code reader and see if there are any fault codes logged.
Hi there, thanks for the reply
Done it plenty of times. "Charge pressure negative deviation" is the response most of the times. Sometimes it points to the Airflow meter, other times it points to the EGR valve. Cannot remember all the fault codes. I don't have my own diagnostic machine. I am dependent on looking over the shoulder of "specialists" and men in the know. Most of them are ready to replace expensive parts to solve the problem. Before I replace the turbo, (all posts and replies I have read so far say it does not help) I have asked (requested Firmly) a friend to do a pressure test on the intake/turbo hoses, and to clean the Intercooler. I am at the mercy of others at the moment, as I am recovering from a Spinal fusion...only another 3 weeks left on my back, then maybe I can attempt these things myself again.The car is 8 years old with 350 000 kms on the clock.
Hi Franscois,
I am also from south africa and suffering the same problem.
Did you manage to come right and fix your polo?
Not yet. A friend is working on it. Will let the whole world know once it is fixed. Such a lovely car but what a pity about this problem,
Regards
