Anybody know of the best clutch to fit 1.4 abd?
I believe this engines just a bored or stroked version of the aav? It has a slight wear ridge on the flywheel by a couple of mm I think it's had a 190 mm clutch but I'll check will a 200mm fit? I hear 6n gti pressure plates have stronger springs or something? Can anyone reccomend a clutch? Will I need the flywheel skimming though? Should I just stick to a 190mm it's not gonna have mega power just carbs gt cam 4 branch ect
Edited by Buxton
  • Views 628
Don't skim the flywheel unless its warped. It should be fine as long as you haven't been slipping a very worn clutch.
Even bog standard 1.4 8v 6n2 models got a 200mm clutch by that time, I'm now thinking I have one in mine. For that power and the weight of that car, that clutch would be fine. Same for any of the 1.4 16v clutches which are also 200mm.
Yeah I was thinking about a 200 mm clutch well I'm unsure I it's warped as it's a new lump to me, I think I might put a tdi gauge on it just to check it's not warped, I'm thinking of
A 2000 polo 1.4 petrol 200mm clutch kit with release bearing it looks like it will fit
So 1.4 16v clutches fit also I've seen uprated ones on eBay not sure of the brand but thier for a mk2 they look like they'll fit but I'm not willing to spend big bucks, are thier any other manufactures that make uprated clutch kits helix or something rings a bell
I used a 190mm in mine mate, thats what cam out of it too
In my opinion you do not need an uprated clutch, a 6n2 GTI clutch kit fits and that is for a 125bhp engine in a car like 40% heavier.
Traction and gearbox strength are issues which come into play before a 200mm clutch starts struggling, in my experience.
Thanks mate 200 mm one sounds just about right I've got a gt box so I hope it will hold up, I was thinking maybe some decent 175 tyres or wider, you must have far more traction and obviously worse gearbox problems Mikey...:) and thanks for the advice I forgot the 6n2s are heavier and that's a factor, going to slap a 200 one on soon :)
Tyres are a wet or dry choice really, haven't got the weight to push too much tread into a wet road surface, a bit of sidewall deflection can help prevent traction breaking once its down on less than perfectly smooth roads, I get on pretty well with 185x60s but 175s are a good all-rounder.
