6n2 cutting out
Hi I've got a 1.0 6n2 about 6 months ago i had a de-cat pipe put on it and had no problem but about 2 weeks ago the car started to cut out while driving, the engine just cut out and the car turned off and the car came to a stop. I had the car put on Dino and it said it was the lambda sensor so I replaced them and put a brand new cat in which did not work. We then found a wire leading to the coilpack that went wobled caused the car to just turn off like it has been doing when driving so we pushed the wire in tight and checked the fitting of the connections which seemed fine. We hoped that would fix it but hasn't done. Does anyone know anything it could be or anything I should check with the coil pack?
Edited by JOSH-VW
  • Views 654
Popular Days
