Polo Gti 6n2 1.6 bike carbs
Hi I'm new on here and have been searching for a while about weather it's possible to put some bike carbs on my polo Gti 1.6 2001 and what gains and losses am I looking at cheers
James
  • Views 2.5k
Any one ???
Putting carbs on your engine is a touch harder that an afh (1.4 16v) as you've no distributor which is normally swapped for a mk2 golf 1.3 one with the rest of its ignition set up. You'll be looking towards building a hybrid engine with your bottom end an afh head or running an aftermarket igniton management such as megajolt or nodiz (I've just finished a group buy on the latter)
As for gains the aftermarket set up and mapped properly will see u most gains.
From 2001 emissions got really tight so carbs get tricky. Add to that, you have to get the carbs to work with two different cam profiles. Then you need an ignition system that can also deal with the flip-flop cam.
I did it. But it wasn't a success, as it wouldn't run perfectly at both stages. I actually got it through an mot but the carbs were so lean it was ready to melt.
I now run it without vvt, using the static cam version of the same head. This being the popular 1.4/1.6 16v head as found in countless Volkswagen Audi Seat and Skoda models during the 1998-2008 era.
