HELP, TRYING TO GET THIS STICKY SHIT OFF
Trying to get this off but its taking forever, any good tips & tricks for getting it off? CHEERS
post-145536-0-28623400-1383777709_thumb.
  • Replies 10
  • Views 960
toffee wheel on a drill
Gently warm it up with a heat gun to melt the glue, pull off what you can (or scrape with a plastic filler card or summat) then panel wipe (the solvent painters use to clean panels with before painting) will get the remaining residue off.
Something like Jizer should work too?
Don't be tempted to use thinners though...
Tar and glue remover?
Well done for getting them off though I took the paint off with my bump strips :L
Edited by vdoubleu
If its like number plate sticky stuff use Nail Polish Remover, but clean it after, thats what i used and it worked a treat, use a bit on some rag/kitchen towel.
Iv also heard petrol works.
This
Oh you should see the other side, the paint was rusting and took a patch off with it!
Tried this earlier started working just got to spend ages rubbing! cheers
Try get some autosmart tardis strong stuff but should remove that
Toffee wheel on a drill definitely
I'm currently doing the same on mine colour coding the side strips that stiff took me hours to get off one strip it's a nighare
