Mk2 Polo Performance
So I've bought a mk2 bready 1.3 1989. Restored the interior, brakes and done varies engine bits and bobs. Just got the Carb left to sort out (PISSBURG) and i hope to be up and running. But I'm already thinking about how to squeeze some speed from the VW. (I know its not a race car but i have to satisfy the boy racer in me). So, where should i start? I've been looking about for a Weber DMTR carb but haven't seen anything promising in my search. I dont have the resources to do a turbo install or anything too awesome at the moment ;). I am essentially looking for a bit of bolt-on or slightly more simple custom performance and don't know where to start. Any ideas/links to threads/info is appreciated guys :). And where might i find such a market for second hand parts or similar :) Any point investing in stainless steel manifolds or eBay bits and bobs? Share the knowledge guys.
  • Replies 26
  • Views 3.1k
Sorry for the terrible layout of that ^
4 branch manifold weber replacment for the pierburg. A gt cam. And then probaly most important a good service plugs lead complete igniton change to the mk2 golf 1.3 setup. That about all with out spending big money. Maybe go for bike carbs instead of weber replacment
webers are nice idea , although no real huge gains unless the pooburg was running so bad its losing big power
I thought about bike carb swap but i would have no idea who i could ask to help build the manifold for such a project without breaking bank. Where should i keep and eye out for a GT cam? And fair play with the POOBURG giving no gains. Is the weber/bike carb idea something i should think about anyway if i am trying to get performance or would the pissburg suffice if i getting it running sweet? Also are bike carbs or any carb swap a big insurance no-no?
Edited by Drewgie
Everything can be found on here. A bike carb manifold can cost around 200 pound made by bogg brothers or dan st. However kits come on here for around the 100-150 mark gt cams are around the 50-60 mark. Performance gains are not cheap u have to spend money to gain a lot.
I'm thinking ill slowly build it up so a 60 here and a few hundred there shouldn't be the end of the world. Hoe feesble would a g40 swap be for the bready? I always try to keep and eye on the forum so hopefully i find some bits for it on here
you realise the 1.3 golf is the exact same as a 1.3 polo?
Would a "performance" ignition coil do me any favours?
not really, unless your original one is stuffed
The early mk2 polos ran a diffrenent igniton system didn't they? Hence y people get the golf stuff as it's electronic. Must be another stupid moment from me lol
yes they run points, but he doesnt have an early mk2 polo lol
the electronic ignition mk2 polos and golfs are the same.
the only difference is the golf loom is longer - handy for hiding things.
I just see mk2 didn't look at year :lol: everything apart from that then unless u wanna hide the amp lol
If i change the cam to a gt one will i need to do any supporting mods? Fuel pump maybe?
And what should i keep my eye out for to know that parts will fit my car? For example would certain g40, golf ect parts fit my motor?
The gt cam doesn't have a mechanical fuel pump drive so you'll need an electric fuel pump
how much do they go for and are they easy to get a hold of?
U can get a a small facet pump on ebay for 20 quid
Cheers for all the help guys. Any info as to the parts that will fit my engine. I believe its the same as mk1 golf engine essentially. but any parts that will transfer as upgrades? sorry for the insanely broad questions here..
mk1 golf would be the 8 bolt rocker solid tappet engine
its the same as a 1300 golf mk2 in most cases , maybe not really early ones
Might as well just chuck a gt conversion in it, would be cheaper than putting bike carbs/gt cam ect on your engine and probably give similar power gains. Also less chance of melting a piston :lol:
Whole engine conversion you mean? Certainly something that is in the back of my mind, but i would quite like to keep it fairly standard for the first year for insurance purposes.
Yeah the whole engine. Any performance mods would effect insurance anyway
I have a full bike carb setup and an ABD cylinder head for sale :) jus' so you know ;)
yeah see what the insurance say ...id say they pretty much have your pants down for any small mods anyway
