Puddle in Drivers side footwell!
Hi folks, car has been beginning to smell foisty lately so decided to check for dampness and discovered that the driver side carpet, liner and floor are saturated in water!
it's only the drivers side no other footwells, and there is no obvious sign of where the water is getting in!, it's not coming from the heater duct nor from the sills or door grommet and I'm quite stumped as it was a considerable amount of water I got out (didnt quite manage to get it all)
any ideas where else I could be getting a leak from? I pulled all the carpet and liner up as much as I could. the sunroof drains correctly and the windscreen scuttle tray drains fine too?
  • Views 1k
What car is it?
If Mk2 or 3 my guess would be the battery tray. Whip it out and have a poke around.
Edited by fathands
Hi sorry I never mentioned it, its a 6n
Edited by R10tz0r
I've got this problem to but passanger side, i found the leak tho its coming from a gromet on the passanger side where I passed my sub live wire through. Its about say 10cm wide, might be worth looking there or could be running in past the seals of the door, drainage holes on the door clear?
Yeah all clear, I think it may possibly be coming from heater matrix, I'm gonna be taking dash out soon so will be able to check then!
