Electric aerial fitting on mk2f gt have you done it ?
Am thinking of fitting an electric aerial on my mk2f gt has anyone done it ? gfs sell one at 42quid can thay be brought cheaper ?
Its it hard to fit on the wiring side ?
Thanks.
  • Replies 18
  • Views 894
Depends when you want it to come on
If you want it to come on with the ignition just wire it to a switched live via a relay
I'm not sure how much current they draw but a relay would be best either way
Not really fussed when it comes on whatever the easy option is ? when you say switched live of the relay you mean I need to use a new one ? sorry for silly question about relay ..
A switched live could be the demister switch for example
You can't run the aerial straight off that switch or you'll blow fuses and melt wires
So you wire the positive terminal of the battery to a new relay, and wire the live from a switch to that
So that when the ignition comes on the relay clicks on allowing the current to flow from the battery to the aerial
You'll also need to earth the relay but the pins should be easy to identify
Ok think I got that shall get myself on ebay for the relays 12v ? not sure on amp though ?
Edited by mazraclou
Ok thanks for your time.
Will I need inline fuse between battery live and relay ?
Yeah I would
With 30amp gauge wire ?
Nah it won't draw 30 amps haha, I would try a 10 amp fuse first, if it blows put something a little more in
alot of head units will have a wire for the elec aerial..roar that onto a relay and it will only come up with the radio
i found they break if its icey out so watch for that
Oh silly me just thought as it 30amp relay that's what it would need ... so pin 30 would be power in from battery with inline fuse ? pin 87 would be to aerial ? and 86 pin to ground ? how about 85 pin on relay ?
Edited by mazraclou
Believe 85 and 86 are your earth and live from the radio/switch
Pin 30 is the battery live and pin 87 is to the aerial
Edited by derskine
I think i got that ... lol
So can i use a toggle switch to activate aerial instead of switch live from when i turn radio on as if i use a cd will be no need to use aerial ?
Will 12awg wire be fine ?
Edited by mazraclou
Yeah that'll be fine.
If you get stuck gives a shout, happy to help
Ok thanks not brought all the gear yet so when I do I shall if I get stuck . I shall do a mock up before I fit it all though .
