vr6 interior into polo 6n2
Hey am I able to put a vr6 leather interior into my polo 6n2 easily ? Any help much appreciated
From what i've read the fronts are a straight fit and the rears need to have the foams and covers swapped over to the 6n2 bases. There's loads of guides like this one http://www.clubpolo.co.uk/forum/index.php?showtopic=68301
Cheers vdoubleu. Just been reading the link and it says the rear bench wont fit the car without serious work but I'm sure there cant be much difference between a 6n and a 6n2 rear bench is there ?
my 6n2 got that leather interior, takes about a hour to do
my brother has vr6 leather in his 6n. you'll need to grind some tabs off the rear bases to get them to fit into a 6n2. it takes about an hour at most.
I had vr6 leathers in mine... You only need to grind/mod shit if you you use the back plates.
So in simple... Swap to polo back plates and it's straight fit.
Took me 10 mins to get entire interior in
They are so easy to swap! Only take about 20 mins :) done it in my old polo.. Front fit straight in and rears you have to swap the backs over witch takes five mins
