wiring help?
hello i wonder if any one can help me?
i have a 2003 reg polo and I'm looking at putting a light in the boot as it dosent have one and obviously at night i cant see what is in the boot.
dose anyone know where i can pick up a 12v constant power supply and how i could tie it into the interior light so when i unlock my car the boot light comes on when the interior one dose.
i hope someone can help
cheers shaun
  • Views 981
It doesnt have a boot light? Are you sure the bulb hasnt blown?
Anyway, you can just t into the interior light live wire. Unfortunately this will be from the fusebox in the front. Have a look at the fusebox layout and find the interior light, you can check by taking it out. Then either trace the wire back to where it can be cut and soldered or use one of these http://www.ebay.co.uk/itm/Mini-Fuse-Tap-Add-on-Circuit-Adapter-Auto-Car-Auto-Terminals-Brand-New-/390651773738?pt=LH_DefaultDomain_3&hash=item5af4a9032a
Then route the cable to the boot in the desired location.
You can either use the boot light from another car, the 6n2 would be good as its just a small square unit. Or make one out of LED's (not that hard), or buy an led bulb and solder it direct. Then just find an earth.
6n2 boot light: http://www.ebay.co.uk/itm/VW-Polo-6N2-GTI-Etc-Boot-Light-Genuine-Not-Rare-/141094598064?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20d9e4b5b0
OR! You can use an Led strip (theres a pic here, 2nd post down, http://www.clubpolo.co.uk/forum/index.php?showtopic=323623&hl=). You can even get a colour changing one, although the white isnt great as its a mixture of RGB.
See here:http://www.ebay.co.uk/itm/12v-LED-STRIP-LIGHT-3528-SMD-300-LEDS-5M-UK-/320681128958?pt=UK_Home_Garden_Night_Lights_Fairy_Lights&var=&hash=item4aaa15b3fe
Or rather then struggling to get more wires through the bulk head just tap into the interior light feed itself or one of the door switches
He shouldnt have to get wires through the bulk head if hes tapping in? I dont know these cars though
No your right I was thinking of something else, my apologies
I recommend led strip, very bright, very economical and cheap as anything if you look in the right place, plus draws a very low current (single colour 3528 is only 2A per 5 meters run)
and do as Chris said a few posts above.
