Sandpaper grades help
Evening people, just after advise really.
Going to be doing some bodywork on my car in the next few weeks, need to know what grades of sandpaper to start and finish with with all grades in between that you would recommend.
Incase it helps I'm doing a scratch on my front bumper, a small bubble of rust on passenger door and a bit of filling/smoothing on the front bumper and one of the sills
Car is 6n2 with deep sills if that matters.
Cheers in advance for any info :thumbsup:
  • Replies 10
  • Views 851
  • Cheers - the whole car came out much better. Roughly 60 to 70 hours of labour though with 240 grit sandpaper, grading down to 2000 grit before polishing. Still not done 100% yet.
400 to 1000 or something like that.
Edited by mattieboi6n
So for getting a rough outline of the shape you will want 120grit at most, make your way down to maybe 600 wet and dry for finishing as the primer and paint will fill small grooves, you need to make sure there are no large gouges from the courser sandpaper before progressing, use the wet and dry wet as it will give a better base to spray,
Hope this helps dude
Ryan
Cheers guys
Personally if you're using aerosols I'd finish flatting the filler with 800, then go to 1200 to flat the primer, the paint has nowhere near the build.
Don't wet flat the filler, as it's porous, if you do want to, to get a smoother finish, then dry it with a heat gun after. Obviously primer is porous too but not as much.
Cheers bud :thumbsup:
I have used 240 grit sandpaper on actual paintwork before LOL - just for flatting back. I was having to remove an entire crappy respray though.
before
using 240 grit
Sanded but not polished
started polishing
Done! No repainting required = result, based on first photo!
more pics and photos on my 924 project at http://www.devoncardetailing.gb.net/my-924.html
Edited by TDIfurby
That's come out awesome!!
Don't sand your filler with 800 grit or your primer won't stick to it!!! It needs a 'key' to grip to!
As a rough guide you should sand the filler down to 180 grit (a bit finer if using aerosols, but certainly no finer than 320 grit) Use a filler primer to fill the sanding marks. It might take a few coats though...
Then sand your primer down starting with 320-400grit down to 800 grit (wet). Again, don't sand your primer any finer than 1000 or the top coat won't stick to it.
Not when using shitty aerosol primer.
You end at 320 and you'll still see scratches.
By all means go over lightly with a scotch pad.
Edited by MaxVW
