6n2 buying questions - erratic idle, wobbly clutch pedal
I'm looking at buying a 6n2 1.4 16v and have a few queries about the difficulty of fixing a few niggles it has. First one is an erratic idle. Car starts from cold fine and initially idles ok. As it warms and the revs start to ddrop the idle starts to become erratic. Kind of drops and jumps up again over and over. smooth sound to it, not a really sudden jump or anything but I'm just wondering if it could be a bif problem. Was last serviced around 10k ago so it needs oil etc doing. Idle control valve maybe?
Second issue is the clutch pedal. It wobbles about a bit. Fairly short through but no noticeable clutch slip. Just a worn bush? Easy fix?
Gear stick wobbles around a bit too. Gear knob is a bit loose which doesn't help with feel. Again, just a bush issue?
Anything else I should look out for? My problem is I'm a bit of a perfectionist so stuff stands out and I don't know what's acceptable and what isn't?!
  • Views 962
Leads or plugs might need changing. When I had a 6n2 I had a problem with the peddle box which could be what is wrong with the one you have looked at. The welds fail on the peddle box causing difficulty getting car into gear and clutch stiffness
My wifes car did the erratic idle bit.
The throttle body just needed a bloody good clean out.
I had the throttle body reset using vag-com.
I have heard that its possible to do this without vag-com but I cant confirm this.
I believe the peddle box suffers the same as the Lupo ones and collapse.
In my experience the gear lever on these are sloppy.
