Drivers door resuses to open.. help.
Right..
Basically.. My interior door handle snapped in my 6n (i have 6n2 dash & doorcards).. Replaced the handle and found the handle wasnt pulling the latch rod far enough to open the car door. Bent the rod a little and it worked perfect both inside handle and outside handle.
Drove to work, locked the car by key and there was a 'clunk' as it something had fallen/come off/snapped. Unlocked the car and the outdide handle refused to work to open the door. The door lock pin still raises with the key to unlock it.
essentially had to smash the window to get into my car and the inside nor outside handles now open the car regardless how much i pull them.
Going to take the doorcard out tomorrow if i can get past my seats and try and fiddle with the latch mech to open the door.
Anyone got any idea what went wrong and how to prevent it happening again in the future? And any tips on how to open the door if i cant get the doorcard off lol.
  • Views 785
take out back seat then you should be able to get door car off think the lock may have falling off the locking bar I had this once before theres a plastic clip that pushed onto the locking rod this may have come off this is what happen to mine ok hope this helps all the best gary
thanks for your reply, all sorted, replaced the latch mech cause i couldnt be bothered messing with the old one. .All sorted now thanks
