Rust
Just found some rust in the battery tray of my mk2f polo 1991 coupe. I knew it was a bad place for rust due to friends having the same problem with the same car. Before I take it to be welded, is there any other areas that I should check that are likely to be bad? It's had a quick check over and it looks okay. Just wondering if anyone else has had any problems :)
  • Views 740
back edge of the sills , around the filler cap , the filler neck on the fuel tank
The thin metal plugs in the rear footwells tend to rot out, you can't see they've rotten due to them being sealed up, I've put my foot through two of them when working inside the car
In two different cars lol
Edited by derskine
Wheel arches, sills, by petrol cap, filler neck, front a need rear valance are the worst bits. Battery trays are so common. I even seen them go on garaged polos.
