mk2 -2f parcel shelf interchangable?
I'm looking for a mk2 breadvan shelf
I've found a mk2f coupe one for sale..would that fit properly?
  • Views 2.1k
One is longer than the other, can't remember which but I assume the coupe is longer than the breadvan one
So it'll either look ridiculous or you won't be able to close the boot :tongue:
I believe a mk2f breadvan shelf will fit a mk2 though
For reference, Mk2 bready and Mk2f bready parcel shelves are exactly the same.
The coupe shelves are shorter, the Mk2 coupe shelf also has a recess for the wiper motor. Mk2 shelves will go in a mk2f but you have to slam the boot and the straps aren't long enough (i know because i bought one for my coupe, doh!). I imagine Mk2f coupe shelves would go in a mk2 if you removed the wiper motor and cover completely, but it probably still won't look right.
^ any way to tell a mk2f coupe vs bread shelf?
Pretty sure the coupes shelf has a larger rise at the back end because the lower edge of a rear window sits higher in a coupe. Thats the best bet i'd say from pictures.
Otherwise it is much shorter than the bready one.
