Mk2f fuel sender
As above, part number: 867919051K.
  • Replies 12
  • Views 306
I think i have one, Il check and let you know.
Cheers.
Where are you?
By sender do you mean pump
I mean sender; drops in the tank. As far as I can tell there is no pump involved.
if its injection there's a pump in the tank too, yours on a carb ?
all mk2f's have lift pumps aswell as a fuel level sensor iirc
Number 2 is the one I'm after and it has the aforementioned part number:
Wasn't sure if it had a pump in it; I was just going to get one and see what I needed to do pump-wise afterwards.
no2 is a diesel lift pump from what i can see.
It is used on diesels, but not specific to diesels according to ETKA.
I do need it for a diesel, however.
my etka lists it for diesel eng, maybe you add more parts to it for petrol use who knows!
It states:
867919051K
fuel gauge sender / fuel gauge sender / VDO / diesel eng. DIGIJET,G40,
use for: / assembly(assy)
867 919 051 M / DIGIFANT, MONOJET, MONOMOTRONIC
If it is diesel specific I'm not likely to find one so will come up with another solution!
  • 3 months later...
Still looking...
