battery tray letting in water
My polo coupe s is letting in water from the Battery tray. I was going to grind out the rust seal and fill it because I can't weld and don't really know we're to take it to be welded in the Nottingham area. Would this be a good fix? Long term as I'm looking to do this myself this weekend any helps welcome people thanks
  • Replies 12
  • Views 1.3k
How big is the hole could always rivet a plate in there and then fibre glass over it then underseal over the top. Bo qater will get past then if done right
Thanks guys it's not a big hole so I think ill go with that so if fibre glass over the plate then underseal it I should be ok I'll give it a go thanks again
sounds like a plan. If it's a tiny hole, you could clean it up, then use POR 15 to paint over the rust, and then use brush on underseal to seal if up.
Otherwise do the same but with fibreglass. Remember the rust is porous so you want to have the edges of the fibreglass over good paint (that you've keyed up)
I'm so glad I join this forum you guys help so much. Right iv Got some fibre glass and underseal just about to take the battery out and remember there's a old alarm fitted that I don't have a fob to! Iv looked it up it has a emboliser on it so I can't disconnect the battery. I haven't got a clue how to take it out iv looked at a thred and can't follow it at all looks like I've got to take it to a garage to get it removed :(
should still be able to pull the battery mate...worst case it will go off when you reconect , so no probs if you have the fob
with the fibre glass make sure the metal is clean , dry and roughed up well with a grinder or something , put some parcel tape inside the car under the dash so it doesnt all all oooze through , then peel it off and put a coat under there once its dry
I don't have the phob n need it out the way really and thanks for the tip that's what I'm Gunna do both sides and underseal it good and proper is there drain holes both sides of the tray then because I find it strange that water runs around the battery or is that normal or should it only run down the other side?
yes its a bad design how the water sits around the battery...its normal but stupid lol
thinking of making a full width tray for mine to keep the worst out
Yea I'm Gunna tidy it up just hope I Fix the leak first it's a wired design defo the alarm really annoyed me today wanted to get it sorted I guess next weekend it will be you guys have help alot! Thanks again I feel like I have the knowledge to tackle it now
Can't you get a new fob and signal it into your existing box?
I understand the problem if you can't weld, but is fiber glassing over a rust hole really a proper fix? I would personally say find someone that can weld (friend, colleague etc) and have it done properly whilst the rust is minimal ad the cost will be small. My Mk2f's tray started to have a small leak, only expecting one small hole i started prodding, turned out there were sections of galvanized steel fiber glassed over the rusty original tray, water had got underneath the fiberglass and rotted the whole lot. Ended up chopping it all out and starting fresh.
I'm not trying to stop you from doing the work yourself, i completely understand having to work on a car you are using daily therefore you want it done quickly, its just better sometimes to take your time and do it once properly.
The back bracket that the battery sits up against had failed on mine the actual brackets was rusty but behind had rusted out could poke 3 fingers through not good.. So drilled out spot welds that held the bracket and cut out affected area about the size of my mobile phone.
I cleaned up area and used rust protection followed by epoxy 121 then fabricated a repair panel and spot welded into place..Painted more epoxy once welded and the applied some underseal over the top. Also inside under the dash I painted with epoxy 121 ...
For me job done but we all have different ways of doing things ...
Edited by mazraclou
