mk2 heaters
the heaters in my car seem to not be working, on a 15min drive to work the heaters still blow cold, previously they would have been hot in about 5mins. i bleeded the system and i think I've got rid of any air but is there anythinv else i need to check or replace, the blow does work on all speeds it just doesnt heat up
any ideas?
  • Views 823
are the pipes going to the heater both hot?
either thinking blocked matrix or theres a small lever on the side of the heater which is like a on /off tap for the heat , that might be stuck on cold
Could it just be that the weathers colder? I know mine takes a while to get up to proper operating temp in the cold, i tend to close the heater thermostat and switch off the blower until it is at operating temp.
Otherwise i would check that the valves being operated (get someone to work the controls whilst you look at the valve under the rain tray), after that remove the heater hoses and flush with a hose, then fresh coolant and bleed.
could be thermostat not opening, if air is getting into water system though and there are no leaks it may be head gasket as well
