Is it possible to replace the plastic 'screen' on Mk2f clocks?
Hi guys,
Is it possible to replace the plastic screen on the car clocks (the clear plastic screen on the face of the clocks).
Is it possible to take this part of the clocks apart and replace a scratched screens with the spotless one I have on my current clocks?
Thanks,
Nick
Edited by Nick_593
  • Views 691
dunno but i have polished mild scuffs and haze off mine in the past
I've seen online that people have removed the plastic screen on Mk2f clocks, to replace dials etc.
Does anyone know how to remove the screen and re assemble?
Edited by Nick_593
Its bonded onto the outer black casing that you see around the clocks. So you need to strip the assembly down - swapping the foil printed biscuit mat and instruments over from one casing to the other.
Its easy, just be very gentle tightening up the brass nuts on the back because those tiny pin-thin studs break easily (even though they seem so tight when undoing them!).
