mot
Hi new to the polos I got a 6n2 and it has a bit of a hole in the boot I filled it in with filler will this let it pass mot
  • Views 508
depends where it is and they can see it
should be welded if within 30cm of suspension points etc ...although if youve done a awesome invisible job then yeah maybe it will go unoticed
Unusual to have a whole in the boot on a 6n2.
That's what I thought its were the drain plug was are the prone to rusting dose any one know
so its a drain plug hole that did have a grommet in it?
Yea its round the outside of were the grommet was about the size of a cd all rotted out b4 I got to good metel
