Mk2f rev counter Conversion- How do tachometer readings compare between 'Cl' & Gt models.
Hi, when swapping clocks over from a Gt into a 'Cl' model, does the tachometer read the RPM correctly?
- GT's max at 5900 RPM.
- AAV's max at 5000 RPM.
So will consideration need to be given when reading the dials with the different RPM between the two engines?
- Might be worth noting for anyone changing their clocks so they don't blow their engines!!...
Edited by Nick_593
  • Views 968
Considering you can put clocks with a rev counter in a 1.0 Fox and such like Polos which didn't have them, then I'd guess that no matter what clocks you put in what the needle shows will be accurate enough.
Also there is a rev limiter there to stop any potential disasters.
