ebay 421 manifolds polo mk1-mk3 any good ?
  • Views 658
I got one a year or so ago
fitment on the block was excellent but my one angles slightly to one side as it goes under the car, close to the heat shield as the mid section joins, I had to rehang the rest of the exhaust to compensate. you'll need to get a lambda sensor boss welded in too if you have a mk2f or later model
I also got the glader arb blocks to stop the ard brushing on the downpipe when cornering. overall it opened up the mid range performance more but lost a bit of power at low revs, sounds nice too
You deffo need arb blocks otherwise the pipe will touch you arb , but mines great and makes the car feel a lot better spins up the wheels easy now if I'm not carefull ;)
sweet cheers for the input lads :thumbsup: already got the blocks ;)
