Reverse light bulb on car not working [Mk2f polo coupe].
Hi, the reverse light on the car has been non existent for at least the past three years [Mk2f polo coupe 1991].
I've done the obvious thing and changed the bulbs etc. Also, completely new rear lights were put in and this has made no difference.
Does anyone know how to go about fixing this issue?
Edited by Nick_593
  • Views 1.3k
Mine's the same. Gearbox switch is what I've put it down to..
Does anyone know how to fix the problem? Will it need a new reverse light switch?
sounds very much like the reverse switch ...easy enough to fit
can test it with a multimeter if you have one
Hi mate dont have a multimeter.
How do you go about changing the reverse light switch, and where is it located?
Also, do you know which one would be needed for an AAV (three different ones on Euro-Car Parts?
