Intermittant scraping noise 6n2 GTI?
Recently bought this car (W plate 6n2 GTI) it is a spot on car apart from this strange noise wich is hard to explain. It's like a grating/scraping noise that only occurs intermittantly in the first couple of minutes of driving then stops completely. If I stop and turn engine off then set off again (no matter if engine has cooled or still warm) I get the same intermittant noise in the first minute or so again. Any thoughts welcome, cheers in advance guys
  • Views 647
Bump
Need to be far more specific than that. Does it work with revs, or with vehicle speed, or with engine speed, what happens when you change gear, or use the clutch, or use the brakes.. etc etc
