Rusty Fuel Tank Breather
Hi Guys
The fuel breather guide pipe inside the 1/4 panel on my breadvan is rusted out,
Has anyone got any tips on replacing this?
I`ve got a few ideas but thought i`d see what you guys will come up with
Adrian
  • Views 705
Remove the breather pipe then weld in a bit of exhaust pipe or something (it'll go on fire if you don't remove it lol)
remove the breather pipe, cut out the rusty outer pipe, replace with some coolant hose and jubilee clips, making sure to treat the remaining rust. Use the new hose as the outer.
