mk2f outer sills what can be used to replicate that finish ? Help
At some point I shall be treating the surface rust on the outer sills but how do you get that texture that is on the outer sills ? is it some kind of stone chip stuff I know its not underseal as have used that before..
  • Replies 15
stone chip paint. can get it from halfrauds
Just had a look but am not a fan of hammerite and a few of the reviews on it are crap lol..
Yes was just looking at u-pol on ebay and googled it and has good reports ,,,
you need a shutz gun to get that kinda texture
plus something like upol overpaintable stonechip
Yes it needs to be overpaintable as they only seem to come in black or grey as for the gun am sure I got one when I brought some waxoyl early on in the year :smile: .. have you used it ?
Found two 1ltr bottles on ebay for £18.49 all in.. but shall carry on my search see if any cheaper prices come up :smile:
The waxoyl one should be a schutz gun
That's what I'm thinking :smile:
metalflake.com has tetrosyl for £5 free posty...I've used em before they're fine
1 ltr would be ample for 2 sills ...be aware its heavy in thinners so may frazzle up any cheapo brush on primers youve used under it
Ok shall check them out was going to use epoxy 121 as the base then u-pol then top coat same colour as car ?
yeah epoxy will be fine ..have a little play with the air pressure , you can vary the texture that way
v low pressure and long distance away it will just spit out an make for a coarser look ..closer /higher pressure for smoother
Yes I got a reg on compressor so will fine the best finish pattern on some scrap metal first .. that metalflake quite good so far I will be buying some panel wipe as I have run out and stone chip and probley other stuff lol..
yeah they're pretty reasonble on most stuff..free posty helps
Took advantage of the free post :smile: 30 quid well spent lol
