6N2 Rears not flush
I followed the guide what everyone uses and re-wired them, I noticed they weren't sitting flush so followed the guide to drill the 15mm hole and file them down which has already been done, but now the 15mm hole has been drilled it doesn't seem to push into it. Heres some pictures;
Sort the wiring aswell.
Edit: just seen the guide and why if your gunna go through the effort use house hold connectors. Solder them and then heat shrink over that.
Edited by mattieboi6n
