removing airbag wheel
Hi guy's, how easy is it to remove the airbag steering wheel from a 6N without exploding the bag ?
  • Views 694
Easy mate,
First disconnect battery and leave for 30mins then undo two allen key bolts on the rearside of the wheel, turning the wheel may make it easier to access.
This will release the airbag portion of the steering wheel, gently pull it towards you, away from the wheel, behind that is the bolt to remove the wheel itself IIRC its 24mm, undo that and the wheel will pull off.
if you are putting it back on, mark on the wheel and spline so that you can correctly align when putting it back on.
I'm hoping to put my Golf Colour Concept leather wheel on, to match my seats.
But I'm weary of never removing an airbag in my life, then doing 2 at the same time.
Yeah I was a bit worried when I took my wheel off the first time haha
