Mk2 coupe gt 1991
Anyone know a simple way to sort this. Just a slight edging, not enough to completely refurbish the entire trim.
post-15736-0-13482200-1386625248_thumb.j
  • Views 782
(Sorry, I can't understand this...)
Did the trim completelly fit the wheel? Or it just don't do that "click"?
if you want to aprt paint it
scotch pad the whole trim , sand up the scuffs with 800 then base coat over the damage then clear the whole trim
prob easier to spray the whole trim really
This is just the edge of a standard GT coupe trim. Fits right to the wheel. Don't want to completely refurb the whole trim, it's in perfect condition. Just edged the trim next to the tyre.
It will be much easier to refurb the whole thing than to try and blend paint into the existing finish
As steve said it just needs a sand, primer and paint.
You'd probably have to do all 4 otherwise though won't match :(
or just a bit on a brush to tidy it up
