Rolling Road Day @ Aldon Automotive Sat 1st Feb 2014
To be honest Iv fucked around a lot and you'll be surprised that some things don't make the difference you'd imagine - weather seems to have more of an effect! What's your base timing set at? I also need to write some part numbers down off your car lol
I feel I should have fucked around more! Base timing is at 'z' with VAC off and plugged. What numbers are they then?
  • Replies 274
  • Views 15.2k
  • Crushed by a horse 8/3 Gearbox breaks 1/1 Engine failure 3/2 Hit up the arse by an Audi A5 TDi 2/1 Too hungover 3/1
  • It's alive! This gearbox has got oil in and everything :) About the running order. Can I go about an hour before the end? Reckon that'll be about right for the RAC getting there.
  • The only time you stall a car at traffic lights, is either when you're learning to drive, or your starter motor doesn't work.
5-6 base I guess, the mk2 dizzy has quite a lot of total timing in them so you can't really go too wild on the base timing anywho, most AFH's I know that have been tweaked on a RR with carbs have ended up with a base timing of 6-7 deg I believe
Saf i got the topcaps,
Liz i've got a spi injection pump :)
I'll see if i can get some 19mm Nuts dude
Jamie. Are you & Sam & oli running? & max?
Double winning Jamie, as I couldn't find a pump! Cheers dude
Damper nut pitch varies, but it's usually 1.25 not 1.5.
I can get a pair, but not by Saturday.
Considering bringing a 1.6 16v bottom end. Bit late to find out if anyone would want it, and it's a bit heavy to drag about for nothing.
1 - Yeti - Slowda Felatio Pikey up truck (75hp)
2 - Harris.racing - BMW 320cd/MK2f coupe
3 - kanokid - Jack Kelly 1.3 breadvan
4 - catweasel - mk3 coupe/mk5 tdi
5 - Vic - Mk2 Saloon 1.4 afh
6 - Mark - Mk2 Coupe 1.4 16v
7 - Jamiedub- Mk2f Polo 1.6 AFH.
8 - Frascano - Mk2f Polo 1.6 AFH
9 - dom604 - mk2 1.6 afh / Vw t5
10 - MikeyMK - MK2 1.6S 16v (non-AFH)
11 - mash - mk4f 1.4 6n2 8v
12 - philpheasant - Octy tdi estate
13 - maxmaxmaxmaxmaxmaxmax - some form of hairdressing support vehicle
14 - andubz
15 - m4ttyf mk2f 1.3 8v
16 - James (G40jez) - G40 or my G60 not sure yet but will be attending
17 - oli - mk2 1.4 8v, 11:1 cruise.. Hahah
18 -
19 -
20 -
hey guys i wont beable to make it due to my gearbox decided to break -.-
soo I've taken my name off the list
11 - philpheasant - Octy tdi estate
12 - maxmaxmaxmaxmaxmaxmax - some form of hairdressing support vehicle
13 - andubz
14 - m4ttyf mk2f 1.3 8v
15 - James (G40jez) - G40 or my G60 not sure yet but will be attending
16 - oli - mk2 1.4 8v, 11:1 cruise.. Hahah
17 -
18 -
19 -
20 -
If the pitch varies, are there two different type of castle nuts then surely? I thought there was only one.
I need to run a die over the threads on one of the shocks to clean it up now :(
Excellent thanks a lot, let me know what you want for it
See you all tomorrow!
2 -
7 - Jamiedub - Mk2f Polo 1.6 AFH.
13 - andubz
14 - m4ttyf - mk2f 1.3 8v
17 -
18 -
19 -
20 -
Not bringing a car now
If the weathers gonna be like it is now tomorrow I'm staying in bed :lol:
Weather looks like it will be dry... :-) but it looks to be cold.
Dont know what weather you was watching :lol:
mine said rain tomorrow
Weather for here tomorrow is windy and Baltic temperatures, no rain
BBC and my phone say its ok in Stourbridge. But that might have changed since I checked :-)
Spoke to Aldon today, they didn't seem that open to any carb tweaking unfortunately. Its all down to time really. I think they must be expecting a lot more than the fourteen or so cars on our list.
Lol , its always duckin freezin :D , ill be attending but not running . Vic i wouldnt worry too much I'm sure there will be plenty of carb fiddlers there :tongue:
Mark you're coming out at night mate, max misses you
bear jel. like, grizzly bear
Up and away I'm waiting on Neil and we'll be off
2 - scrubbersam - AFH bready
13 - andubz
17 -
18 -
19 -
20 -
any results yet?
Yeah, anything 16v with carbs is gay
