wet foot well mk2f
hey doods I've recently discoverd my drivers foot well id swimming with water. I've felt above the pedals and its bone dry... any ideas where it could be cumming from?
  • Views 959
Door seal, membrane behind the door trim, battery tray.
or rotten screen surround
best get the door card off and the lower dash and have someone lash a hose pipe over it all while u watch for drips
Try feeling around where the bonnet release catch would be if it were on the drivers side, mine was exactly the same as this and turned out to be a little trickle from the battery tray area, sealed over the whole battery tray and it's now gone.
Also if your getting water sitting above the carpet you need to strip it out before it starts to smell because the underlay starts rotting, I've replaced mine with quality home underlay with a foil back and it's a lot warmer and quieter before :)
