9n and 9n3 with water in front foot wells
Hi there I have two cars with the same problem!!! Water leaking in the front! I have checked door seals and all ok. Can't any body tell me how to clear the front drains please.
  • Views 693
mine was having same problem it wasn't the drains or seals it was the rear washer pipe which was broken ( don't know what caused) I try to fix it myself but extremely hard to see I took a garage I know they took £30 pounds to fix relieved all the problems. You can try yourself by filling the washer with some foamy ready mixed washer you will see the difference. I found out problem by this way and try to use the rear washer on a dry day you will see the leak from passenger foot side.
Found the problem!!!! The bolt that holds the wing on right by the front window was missing and allowing water to run into the car! Thank you for your help.
