Expensive parts from VW
So I took a trip to VW today to get some headbolts and a new headgasket for my 1.6 AFH. Told the guy I can't give him the reg but have the part number to the bolts and told him which engine they could be found on. He found them on the system, asked if I needed a full set of ten, to which I replied yes, he then said that we have a bit of a problem, they are £9.93 each plus VAT. I just looked at him silently and told him I'd just have the headgasket. Took a 200yard trip round the corner to Euro CarParts where for a set of ten headbolts which I needed was £15.30 including VAT.
I knew going to main dealer was always expensive but really, £100+ for a set of headbolts for a 1litre, granted they do come on other models like the Lupo GTi but to me that's far too much.
What's the most expensive part you have gone to buy before seeing the price tag from VW?
  • Replies 27
  • Views 2.4k
  • At least they're available. When we were looking at doing the HG on the GT5 we were looking at having to get 3 head bolts from one place, 4 from another, 4 from somewhere else and reuse one.
  • Had this with some injector seals on my golf racecar, something like £4 each. Can get a pack of 10 for £4.20 online
  • I remember buying a hose for my g40 and it cost me £100 +.
That's the price for proper AFH head bolts
Didn't know the 1 litre ones are the same price
Appears that way as on screen I told him that the engine code is AER
i've just bought a headgasket and head bolts from VW and the bolts were like £8.50 each for an AMF engine. i've heard bad things about euro head bolts snapping and stuff so i thought i might as well just pay the money for genuine parts and kick off with VW if they snap...
Now you tell me about Euros headbolts Andy -.- haha. I would of paid full for them, but considering for both my AVY and AFH engines with gearboxes and hubs ect, only cost me 320 for both. I didn't fancy another 100 on top of that
I had to use VW for the the power steering pipes for my old 1991 Corrado 16v...£193+vat for the nearside and £130+vat for the offside.
Always the way, my nearest main dealer wanted £21 each for a ignition lead!?!?! Ended get a set from my local parts centre for 30. Don't know where they get there prices from.
Could you not get a hydraulics place to make them for you? I've just done this for a pipe on a caddy which was a mix of SDI and TDI, and they weren't bad on price at all.
I try and avoid VW if I can get the parts I need from elsewhere as VW prices are just shocking sometimes. Thats if they even have the parts, most of the time I just get told what I'm looking for is discontinued.
BMW have good parts prices though, for my E46 328 I needed a new throttle cable and inlet hose. Bought them both from BMW for under £30 for the two including VAT. I doubt pattern parts from a motor factors would have been much cheaper if any.
It's weird that. In my experience BMW bits are still expensive from a dealer. Just the aftermarket stuff isn't as noticiably cheaper as VW parts are
Normally, I buy pattern parts for the Polo because they are cheap and most of the stuff is of serviceable quality. However, i recently had a problem with front brake discs. i bought a set from my usual suppliers in Wrexham, and they warped within 3000 miles. I took them back and was told that they had warped because of my driving style! Since a set of front pads last me the best end of 20K miles I took umbrage and eventually they gave me another set of discs. These warped within 3000 miles too, so i went to VW for a pair. OK, they were each twice the price of a pair of pattern ones, but the problem is solved. It appears that you pays your money and you takes your choice.
my 1.6 hybrid is built on pattern parts. done quite a few thousand miles now without issues touch wood! i did have to go VW for flywheel bolts and a couple o rings though.
Dizzy O ring seal was £8!
Any think I've brought for my BMW hasn't been too bad, but I've not brought much, £90 for a rocker gasket set i remember.
a lot of the time it does work out better to buy genuine, some stuff is false economy buying pattern
Best stuff to get genuine are engine sensors and body panels. The rest u can get the same quality for a lot cheaper generally
Nope, VW stuff is always more cost effective.
For me, it depends how long I'm keeping the car and if I'm working on someone elses car then it is their call.
I've bought loads of parts fro main dealers in Crewe over the years and never thought they are expensive really
Adam asked about 6 flywheel bolts from BMW for his M60 lump - 900 pounds please...
ermmmmmmmmmm. Bargain!
Needed a pin for my rear drum brakes, £25. Got a whole drum brake hardware kit for £5 from them :D A lot of the older parts are just waiting to be chucked in a skip.
gearbox oil from VW dealer by me is cheaper than any other brand i can find anywhere :p
Alternator bolt for the G was just under a tenner. To this day its still held in place with a bolt thats just as good.... well i think it is as I've not had the need to look :)
Buying genuine nuts and bolts is probably the most expensive things to buy from dealers, as they price everything per bolt.
I have a receipt for almost £50 for the 4 x Allen screws on top of the G40 charger, 2 x screws for the expansion bottle and 20 x drive shaft bolts. I had to buy 20 as they only sell them in bags of 10, even though they price them by bolt and you need 12 for a car!!
That's if they still have the older bits, everything I've wanted for the G40 in the last few years has been discontinued! Apart from the new bolts to do the rear disc conversion, but that's only because they come from a mk2 Golf.
