6N headlight adjustment
Hi, I've just replaced my reflector headlight on the O/S, obviously it needs adjusting, I cannot for the life of me figure out where the nob/cog is to adjust it. It's the electric 7 pin lamp.
  • Views 1.6k
The up down adjuster is on the indicator side, so remove the indicator and have a peek or feel behind at the top side of the lamp. The side to side adjuster is on the other side and I think you have to poke something through a hole to turn it.
I had a lot of time to do mine and I kept removing the whole lamp adjusting it and re fitting.
I can upload a picture, but if you look at the back of your old one you should get the idea.
