6n front on a 6n2 gti?
Anything not obvious going to be a problem?
Wiring etc?
  • Views 751
Being honest, I put this topic in as a way of finding my old topic!
http://www.clubpolo.co.uk/forum/index.php?showtopic=232048&page=1entry1988986
But does anyone have any build thread links to one being done?
Things changed for me a few years ago, hence still buzzing about in the bora. But now in a position to have a hot (ish!?) hatch again
Given the xenon gti headlights, would it really be easier to buy a 6n and maybe add a 1.6? Is there a 1.6 from somewhere else in the vw range without the variable valve stuff that I could bike carb or throttle body?
People fit 6n2 fronts to 6n's so it should work the other way.
Need a few bits though,
Bonnet
Wings
Bumper
Lights
Slam panel
Etc.
You can fit the 1.6 to a 6n, running VVT would be possible with after market management on throttle bodies, or even retro fitting the GTI management into a 6n.
You can also fit a 1.4 16v head to the 1.6 bottom end and run a distributor with carbs
Last option but with megajolt, I think
Thanks for reply
