Help! Water leak
Hello, I have just joined this club
My little polo has currently got a leak in the spare wheel well and right hand side quarter panel I believe it is coming from underneath the rear light by the bumper as there was a big build up of water just wondered if anyone else has had this problem or know any solutions
  • Views 677
Popular Days
Check the seals around the boot/windows etc. If you think you know where its coming from then sit inside and let someone spray water at the area. Or try to jam/tape a rag where you think the leak is coming from, if water has appeared but the rag is dry then its not there.
Just keep trying different areas. You could get a smoke machine and stick it inside and look where its coming out of. Or get some UV water stuff then use a UV light to trace it ;).
